chrisr1
Nov 28, 2016Initiate
R7000 keeps dropping wifi connection
Hi, I have a Netgear R7000 router which I purchased 4 months ago. Recently it has been dropping the wifi connection intermittantly which seems to be getting worse, which is really annoying when try...
- May 03, 2017
Hi Garyr51,
Try to reset the router to factory default and reconfigure it manually. Change the channel of both 2.4Ghz and 5Ghz.
Hi PChell,
If your device is D7000, I would suggest posting it under DSL modem.
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
sjavanovich
Mar 14, 2017Initiate
Having the same problems.. thought it was the crappy Netgear USB Wifi AC1200 (which has also had tons of problems).. replaced with a Linksys usb. works better but still having drops. I think it is the $200+ R7000...... Tried all the ideas.. reset, hardware reset, channels, my provider looked at it twice..
Netgear.... come up with a solution or should i just go with all linksys?
sjavanovich
Apr 29, 2017Initiate
Not sure but my problem is fixed.. bought a new computer with a new wireless nic card installed, and also purchased a new Internet modem. It may have been the modem that could not handle transfer rates. The modem was supplied by charter. I went out and purchased a Netgear Modem to connect to the 7000. Seems to have cleaned up some of the random stuff. That was after 3 months of fighting with the 7000 and the cable company who didn't think the modem was the issue. try a new modem and maybe you will clean up the problems?
- PChellApr 30, 2017Initiate
I have just installed a D7000 due poor wifi with my providers router (TalkTalk) and ongoing issues from line into property.
Wifi is so much better but the router, which appeared to work fine for a few days now keeps losing connection, it can be ok for a few minutes or a few hours.
My desktop PC is wired directly to router, this also loses internet connection.
As the D7000 has it's own modem I need to look at the router as being the problem... or it gets returned as faulty and buy a different router.
