galiganu
Feb 29, 2016Aspirant
R7000 limiting internet speed
Hi I have a speed issue with my R7000. If I connect my PC with LAN to the ISP modem, I get 150 Mpbs download and 75 Mbps upload speeds. If I put the R7000 in the middle (LAN cable from modem to R7...
- Retired_MemberFeb 29, 2016
If QOS is off there isn't much else that would limit a wired connection up upload.
You might try 1.0.4.30 FW and or switch the cables around
Retired_Member
Feb 29, 2016If QOS is off there isn't much else that would limit a wired connection up upload.
