Spartin153's avatar
Spartin153
R7000 looses access and password weekly
First started off about every other month I would loos internet access but I figured it was probably my ISP changing IP address, then recently I have been having to restart my router weekly for the past couple weeks because I will all the sudden loose internet access then several minutes later I will loose WiFi connection and can’t even access with a hardwired computer. Also when this happens and I try to re access my network it says my WiFi password is incorrect. But if I re boot my router it goes back to normal like nothing ever happened.
  • plemans's avatar
    What modem/gateway is the R7000 connected to?
    What firmware is on the R7000? It hasn't been known for the best firmwares.
    The agreed upon stable version is the 1.0.9.42
    But some have had luck with the newest 1.0.11.116
    Any changes in frimware to the R7000 should be done over a hardwired connection. I also recommend a factory reset and a clean install for best results.
