fstarne
Dec 30, 2015Aspirant
R7000 New Firmware 1.0.6.28 released
New Features: Supports Arlo camera. Set up the R7000 as an Arlo base station and connect an Arlo camera to the R7000 without needing an extra base station.. Bug Fixes: Fixes the issue in which ...
- May 25, 2016
If you are going backwards in release number you might still have them (that is from one of the older recalled beta's). However there is NO guarantee they will work. In cases like that you have to RESET the router and then re-apply manually your setting for proper operation.
If you are moving up from and older official release, like V1.0.4 or older you don't need to reset the router but it is advised. In this case I'd give it a try, have any problems, reset and re-enter is the first thing to try. DO NOT load saved settings from any other version into a new one. That seems to be asking for trouble these days.
01R
Dec 30, 2015Luminary
ipv6-test.com
Score
15 / 20
How can you improve your score ?
Your router or firewall is filtering ICMPv6 messages sent to your computer. An IPv6 host that cannot receive ICMP messages may encounter problems like some web pages loading partially or not at all.
- mondenathDec 30, 2015Prodigy
Can any one confirm if the download manager still exist. Or there any other changes in the new firmware. Like a functionality missed kind of. I dont know if the download manager optimization had reduced the file size to 1.5MB
- shamarinDec 31, 2015Virtuoso
Download manager still exist in this firmware. You can use it.
- chascentDec 31, 2015Luminary
To me it seems that the Beta firmware is faster. Screen refresh when logged into the router
is slow. Do we need to do a reset if coming from the beta to this?
CC
- csfongDec 31, 2015Aspirant
Is ReadyShare working ok in this release ?
