Drune
Jul 23, 2015Aspirant
R7000 optimal settings
Hello i have a r7000 nighthawk router. It operated at half speed for wifi from my previous router. I have a 20 Mbps connection and the previous router reflected that speed with speed tests over wifi...
- Jul 23, 2015
Drune wrote:Hello
i have a r7000 nighthawk router. It operated at half speed for wifi from my previous router. I have a 20 Mbps connection and the previous router reflected that speed with speed tests over wifi. My new router (r7000) now is broadcasting at half speed. For example my speed tests are about 8 Mbps wifi. I talked to tech support and I changed a few settings and it worked good 20 Mbps wifi speed . The settings changed when I power cycled my router. I was just wondering if someone could assist with settings cause my tech support expired. I know very little about settings so any help is appreciated.
Dave
Not sure I understand? Support had you make changes to settings and it worked over wireless is what you state, but not what speed your wireless is at, N or G? Also a power cycle or router reboot should hold your settings. If you RESET it will not.
So 4 questions:
- What do you mean by 'power cycled'?
- What is your wireless device speed and are you testing the same distance away from the router?
- What 'band' are you on?
- What are you using to determine your speed?
Also, can you take a screen shot of your WIRELESS settings (hiding some 'personal' info) or at least see if it matches mine:
Of course on either band you could have interference. Have you tried other bands? A program like Acrylic WiFi (https://www.acrylicwifi.com/en/wlan-software/wlan-scanner-acrylic-wifi-free/) will show you other wifi's near you and possible overlap/interfernce and show you open band you can use.
racingmatt73
Jul 24, 2015Aspirant
I have the r7500 ,why did you disable qos and what do you mean by wireless client ?
