chkarta
Oct 31, 2016Aspirant
R7000 or EX7000 for AP use
Hello all. It is my first time/post here since i want to buy a good AP. In all the reviews i read that R7000 has great wifi performance. Same applies to EX7000 as well. I want to use it o...
- Nov 02, 2016
Thanks for your input.
I finally ordered the EX7000. Routing options were not needed and i considered that a clean option could be better.
I intend to install the .32 firmware that is supposed to be issue free regarding basic functions.
Can you tell me the fw version you are using?
I read somewhere that for better signal/performance i should choose Japan as a country setiing. Is that correct?
Thanks again.
netwrks
Oct 31, 2016Master
if you want a device that could be a back up router, then the choice would be the R7000, as the EX7000 is an extender / AP, if configured that way..
chkarta
Thanks for the reply.
First thing i want is stable wifi performance.
Only if both perform equally good(and stable) i will choose the R7000 for the extra routing option.
I want to know which one is more stable in AP mode.
- netwrksOct 31, 2016Master
I have used both in AP mode. WIFI is based on your local environment. What works well for me / other, may not work well for you..
