chkarta
Oct 31, 2016Aspirant
R7000 or EX7000 for AP use
Hello all. It is my first time/post here since i want to buy a good AP. In all the reviews i read that R7000 has great wifi performance. Same applies to EX7000 as well. I want to use it o...
- Nov 02, 2016
Thanks for your input.
I finally ordered the EX7000. Routing options were not needed and i considered that a clean option could be better.
I intend to install the .32 firmware that is supposed to be issue free regarding basic functions.
Can you tell me the fw version you are using?
I read somewhere that for better signal/performance i should choose Japan as a country setiing. Is that correct?
Thanks again.
Retired_Member
Oct 31, 2016The r7000 is a reliable stable router In my opinion, yes FW has caused loads of problems in the past year. The good news in my opinion is they are working to undo the colossal screw up and older FW versions work quite well.
- chkartaOct 31, 2016Aspirant
Can you tell me the FW version you are using ?
- Retired_MemberOct 31, 2016
V1.0.4.28 or V1.0.4.30 the latter worked great and if they never came out with another they'd be better off. read the releas notes after .30 they introduced smart connect which to me was the beginning of the end.
