chkarta's avatar
chkarta
R7000 or EX7000 for AP use
Hello all.   It is my first time/post here since i want to buy a good AP.   In all the reviews i read that R7000 has great wifi performance. Same applies to EX7000 as well.   I want to use it o...
  • chkarta's avatar
    chkarta
    Nov 02, 2016
    Thanks for your input.
    I finally ordered the EX7000. Routing options were not needed and i considered that a clean option could be better.
    I intend to install the .32 firmware that is supposed to be issue free regarding basic functions.
    Can you tell me the fw version you are using?
    I read somewhere that for better signal/performance i should choose Japan as a country setiing. Is that correct?
    Thanks again.
