chkarta
Oct 31, 2016Aspirant
R7000 or EX7000 for AP use
Hello all. It is my first time/post here since i want to buy a good AP. In all the reviews i read that R7000 has great wifi performance. Same applies to EX7000 as well. I want to use it o...
- Nov 02, 2016
Thanks for your input.
I finally ordered the EX7000. Routing options were not needed and i considered that a clean option could be better.
I intend to install the .32 firmware that is supposed to be issue free regarding basic functions.
Can you tell me the fw version you are using?
I read somewhere that for better signal/performance i should choose Japan as a country setiing. Is that correct?
Thanks again.
TheEther
Oct 31, 2016Guru
+1
My R7000 is over 2 years old (approaching ancient in Internet years). It was rock solid with 1.0.4 firmware. Netgear stumbled with 1.0.5 and 1.0.6, but appeared to have mostly recovered with 1.0.7. These days I run third party firmware, which has great support for the R7000.
IMO, it's still one of the best bang for the buck routers on the market. Sure, you can get bigger, more expensive routers with more radios and faster CPUs but in many cases it's wasted money.
Between the R7000 and the EX7000, go for the R7000. Netgear tends to pay more attention to its routers.
Retired_Member
Oct 31, 2016+ 2
I now have 2 Triband as their called and both are all hype.
