chkarta
Oct 31, 2016Aspirant
R7000 or EX7000 for AP use
Hello all. It is my first time/post here since i want to buy a good AP. In all the reviews i read that R7000 has great wifi performance. Same applies to EX7000 as well. I want to use it o...
- Nov 02, 2016
Thanks for your input.
I finally ordered the EX7000. Routing options were not needed and i considered that a clean option could be better.
I intend to install the .32 firmware that is supposed to be issue free regarding basic functions.
Can you tell me the fw version you are using?
I read somewhere that for better signal/performance i should choose Japan as a country setiing. Is that correct?
Thanks again.
chkarta
Nov 02, 2016Aspirant
Thanks again.
mondenath
Nov 02, 2016Prodigy
if you download via deskpc or lap which support lan cables. Wireless Bridge would be the best option. If it is also used by other smart devices client then it may not be right option. Range extender is only option.
try to set the security simple if possible and do try as AP if you can wire it and if the extender can reach then 2nd floor. As AP will be best option being extender are capble of close to 700mw of antenna power when compared to r7k may not even be close enough.
