RAiNleet
Aug 04, 2015Aspirant
R7000 or R7500
Hello, im about to buy a new Router and want to take either the R7000 or the R7500. The price isn't really that problem, the R7500 is only about 20€ more expensive. Important is the stability and...
- Aug 04, 2015
It's your call of course. I'm quite happy with my 7000's.. The architecture is Qualcomm, which did not work out the way they intended. If you see the 7500 on sale, it's for a reason.. I'll tell you this te sweet spot won't be the 7500.. But, hey, it's your $$$..
netwrks
Aug 04, 2015Master
The 7000 is a more stable router than the 7500. The AC1900 is the sweet spot at this time. You can check out this SNB on the subject. They talk about other devices, but also about the the two routers you are interested in..
http://www.snbforums.com/threads/old-dude-help-me-build-new-ac-network.25505/#post-190017
