RAiNleet
Aug 04, 2015Aspirant
R7000 or R7500
Hello, im about to buy a new Router and want to take either the R7000 or the R7500. The price isn't really that problem, the R7500 is only about 20€ more expensive. Important is the stability and...
- Aug 04, 2015
It's your call of course. I'm quite happy with my 7000's.. The architecture is Qualcomm, which did not work out the way they intended. If you see the 7500 on sale, it's for a reason.. I'll tell you this te sweet spot won't be the 7500.. But, hey, it's your $$$..
VE6CGX
Aug 04, 2015Master
At present R7000 is more mature and it has some 3rd party f/w options as well; Merlin, Kong's dd-wrt. etc.
I had both one time. It was a haste to replace R7000 running very well on dd-wrt. Had R7500 for a month or so
and replaced it with Linksys EA8500 which is very stable. I have quite a few things connected to this router
on our home network.
