RAiNleet's avatar
RAiNleet
R7000 or R7500
Hello, im about to buy a new Router and want to take either the R7000 or the R7500. The price isn't really that problem, the R7500 is only about 20€ more expensive.  Important is the stability and...
  • netwrks's avatar
    netwrks
    Aug 04, 2015
    It's your call of course. I'm quite happy with my 7000's.. The architecture is Qualcomm, which did not work out the way they intended. If you see the 7500 on sale, it's for a reason.. I'll tell you this te sweet spot won't be the 7500.. But, hey, it's your $$$..
