mahimahi524
Feb 01, 2017Follower
R7000 OSX VPN not working
Followed the instructions on: http://kb.netgear.com/25389/Enabling-VPN-service-on-a-Nighthawk-router-using-a-MAC-OS-computer
Only getting the yellow message "waiting for server response."
Here is the log from Tunnelblick:
2017-02-01 15:30:36 *Tunnelblick: Established communication with OpenVPN
2017-02-01 15:30:36 OpenVPN 2.3.12 x86_64-apple-darwin [SSL (OpenSSL)] [LZO] [PKCS11] [MH] [IPv6] built on Nov 17 2016
2017-02-01 15:30:36 library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09
2017-02-01 15:30:36 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:1337
2017-02-01 15:30:36 Need hold release from management interface, waiting...
2017-02-01 15:30:36 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:1337
2017-02-01 15:30:36 MANAGEMENT: CMD 'pid'
2017-02-01 15:30:36 MANAGEMENT: CMD 'state on'
2017-02-01 15:30:36 MANAGEMENT: CMD 'state'
2017-02-01 15:30:36 MANAGEMENT: CMD 'bytecount 1'
2017-02-01 15:30:36 MANAGEMENT: CMD 'hold release'
2017-02-01 15:30:36 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
2017-02-01 15:30:36 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2017-02-01 15:30:36 Socket Buffers: R=[196724->196724] S=[9216->9216]
2017-02-01 15:30:36 MANAGEMENT: >STATE:1485991836,RESOLVE,,,
2017-02-01 15:30:36 UDPv4 link local: [undef]
2017-02-01 15:30:36 UDPv4 link remote: [AF_INET]72.194.208.188:12974
2017-02-01 15:30:36 MANAGEMENT: >STATE:1485991836,WAIT,,,
2017-02-01 15:30:36 *Tunnelblick: openvpnstart starting OpenVPN
2017-02-01 15:31:36 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2017-02-01 15:31:36 TLS Error: TLS handshake failed
2017-02-01 15:31:36 SIGUSR1[soft,tls-error] received, process restarting
2017-02-01 15:31:36 MANAGEMENT: >STATE:1485991896,RECONNECTING,tls-error,,
2017-02-01 15:31:36 MANAGEMENT: CMD 'hold release'
2017-02-01 15:31:36 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
2017-02-01 15:31:36 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2017-02-01 15:31:36 Socket Buffers: R=[196724->196724] S=[9216->9216]
2017-02-01 15:31:36 MANAGEMENT: >STATE:1485991896,RESOLVE,,,
2017-02-01 15:31:36 UDPv4 link local: [undef]
2017-02-01 15:31:36 UDPv4 link remote: [AF_INET]72.194.208.188:12974
2017-02-01 15:31:36 MANAGEMENT: >STATE:1485991896,WAIT,,,
2017-02-01 15:32:36 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2017-02-01 15:32:36 TLS Error: TLS handshake failed
2017-02-01 15:32:36 SIGUSR1[soft,tls-error] received, process restarting
2017-02-01 15:32:36 MANAGEMENT: >STATE:1485991956,RECONNECTING,tls-error,,
2017-02-01 15:32:36 MANAGEMENT: CMD 'hold release'
2017-02-01 15:32:36 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
2017-02-01 15:32:36 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2017-02-01 15:32:36 Socket Buffers: R=[196724->196724] S=[9216->9216]
2017-02-01 15:32:36 MANAGEMENT: >STATE:1485991956,RESOLVE,,,
2017-02-01 15:32:36 UDPv4 link local: [undef]
2017-02-01 15:32:36 UDPv4 link remote: [AF_INET]72.194.208.188:12974
2017-02-01 15:32:36 MANAGEMENT: >STATE:1485991956,WAIT,,,
2017-02-01 15:33:36 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2017-02-01 15:33:36 TLS Error: TLS handshake failed
2017-02-01 15:33:36 SIGUSR1[soft,tls-error] received, process restarting
2017-02-01 15:33:36 MANAGEMENT: >STATE:1485992016,RECONNECTING,tls-error,,
2017-02-01 15:33:36 MANAGEMENT: CMD 'hold release'
2017-02-01 15:33:36 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
2017-02-01 15:33:36 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2017-02-01 15:33:36 Socket Buffers: R=[196724->196724] S=[9216->9216]
2017-02-01 15:33:36 MANAGEMENT: >STATE:1485992016,RESOLVE,,,
2017-02-01 15:33:36 UDPv4 link local: [undef]
2017-02-01 15:33:36 UDPv4 link remote: [AF_INET]72.194.208.188:12974
2017-02-01 15:33:36 MANAGEMENT: >STATE:1485992016,WAIT,,,
2017-02-01 15:34:36 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2017-02-01 15:34:36 TLS Error: TLS handshake failed
2017-02-01 15:34:36 SIGUSR1[soft,tls-error] received, process restarting
2017-02-01 15:34:36 MANAGEMENT: >STATE:1485992076,RECONNECTING,tls-error,,
2017-02-01 15:34:36 MANAGEMENT: CMD 'hold release'
2017-02-01 15:34:36 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
2017-02-01 15:34:36 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2017-02-01 15:34:36 Socket Buffers: R=[196724->196724] S=[9216->9216]
2017-02-01 15:34:36 MANAGEMENT: >STATE:1485992076,RESOLVE,,,
2017-02-01 15:34:36 UDPv4 link local: [undef]
2017-02-01 15:34:36 UDPv4 link remote: [AF_INET]72.194.208.188:12974
2017-02-01 15:34:36 MANAGEMENT: >STATE:1485992076,WAIT,,,
2017-02-01 15:35:36 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2017-02-01 15:35:36 TLS Error: TLS handshake failed
2017-02-01 15:35:36 SIGUSR1[soft,tls-error] received, process restarting
2017-02-01 15:35:36 MANAGEMENT: >STATE:1485992136,RECONNECTING,tls-error,,
2017-02-01 15:35:36 MANAGEMENT: CMD 'hold release'
2017-02-01 15:35:36 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
2017-02-01 15:35:36 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2017-02-01 15:35:36 Socket Buffers: R=[196724->196724] S=[9216->9216]
2017-02-01 15:35:36 MANAGEMENT: >STATE:1485992136,RESOLVE,,,
2017-02-01 15:35:36 UDPv4 link local: [undef]
2017-02-01 15:35:36 UDPv4 link remote: [AF_INET]72.194.208.188:12974
2017-02-01 15:35:36 MANAGEMENT: >STATE:1485992136,WAIT,,,
I actually figured it out. AT&T didn't properly set my modem in bridged mode like I'd asked them to. So the modem was giving my router a 192.168.1.x IP.
After they changed the modem settings and my router got a public IP, I'm working.
- JamesGLNETGEAR Employee Retired
Hi mahimahi524,
1. What is the firmware version of the router? Make sure to update it.
2. Reset the router to factory default and reconfigure. Regenerate a new certificate after the reset.
