Mgwinn's avatar
Mgwinn
R7000 Port Blocking
Hello. I have set up port forwarding but I would like to restrict the access to it by external inbound IP address.. Is this possible?
  • AFAIK, this is not possible with stock firmware.  Some 3rd party firmware can do it.  If you are port forwarding to a computer, then you can set up filtering on the computer.
    • Mgwinn's avatar
      Mgwinn
      thank you. I will be returning this product. A 40$ linksys box can do this just fine. No reason a 160$ netgear can't
