hantrax
Sep 09, 2020Tutor
R7000 problem
Hi guys,
I have an R7000 modem router, connected via WAN to another modem router (broadband modem)
A few weeks ago I had a problem, the internet led was flashing fast from white to orange.
I did a hard reset and the problem disappeared, now it's back, I can surf the internet.
If I use the android app, it tells me it's offline...
Do I have to do a new hard reset? or is there a hardware problem?
the firware installed is V1.0.10.90_10.2.90
If I buy a new router, can I use the R7000 configuration file to configure the new router?
https://community.netgear.com/t5/x/x/m-p/1900901#M155834
I'd try different (older or newer) firmware before condemning the
hardware.> If I buy a new router, can I use the R7000 configuration file to
> configure the new router?That should work if "the new router" is an R7000.
> router (broadband modem)Cascadung multiple routers is probably a bad idea, too. What,
exactly, is your (unspecified) "another modem router"? Or is it
actually a "(broadband modem)"? If it is (or includes) a router:Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Set Up the Router as
a WiFi Access Point".
a WiFi Access Point".- hantraxTutor
Thanks...I updated the firmware to the new version and now work fine..
Stefano
