Fademan's avatar
Fademan
Tutor
Oct 15, 2021
R7000 Router connectivity and setup problem
Hi there,
I just recently pulled out my old R7000 router from storage in an attempt to deploy it in a new network.
Because I couldn't remember how it was configured, I used the "Reset" toggle at the back and it reset itself.
I then attempted to connect to it, with no success:
- I connected a laptop to one of the LAN ports via ethernet at the back so I could get to the console - the LAN indicator light stayed off and the laptop said "no cable connected" (the cable is fine - i checked).
- I then connected the WAN port to my home modem (so internet was detected), and repeated the above step - with the LAN port not detecting the laptop at all (laptop reporting cable unplugged, router no indicator light).
In the above scenarios - I attempted to turn on / off the router while connected with a cable. The LAN indicator light turned on during the 'boot up' sequence, then turned off once the Wifi indicator lights activated.
- I downloaded the Netgear app on android, and while my phone found "NetGear-5G-Guest" and "Netgear-Guest" - I couldn't connect to either of them - "couldn't authenticate connection" and would drop out / the app path failed.
I'm at a loss here - unless I can somehow connect to the thing and set it up, its nothing more than a brick.
Any suggestions would be helpful. Thanks.
  • plemans's avatar
    Have you tried resetting it again? Push and hold reset for 7-15 seconds while powered on?
    If that doesn't help, you can try recoverying it.
    You can try recoving it with tftp or nmrpflash.
    are you on windows? if so, follow this guide
    https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
    just make sure you enable tftp
    https://www.thewindowsclub.com/enable-tftp-windows-10
    and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
    https://www.youtube.com/watch?v=R9DLrLQrpaw
    and if that doesn't work, you can try using nmrpflash
    https://github.com/jclehner/nmrpflash
    • michaelkenward's avatar
      michaelkenward
      I see  no hint in the first message that this R7000 is bust. No reference to a flashing power LED.
      The fact that the wifi networks are visible suggests that the router is far from "bricked".
      If not, then it would be unwise to attack it with anything ekse. That might break it.
      It  might help to tell people what this "modem" is that is mentioned in the first message from Fademan.
      • Fademan's avatar
        Fademan
        Tutor
        Thanks for getting back to me.
        On further examination - while I thought I had "reset" the device by holding the reset button for 7 seconds - the default wifi SSID "NETGEAR89" (mentioned on the rear of the device) is not being discovered - so I think it hasn't actually reset itself (possibly its only restarting), and its possible that I borked up something in the past in the configuration.
        I can see NETGEAR-5G-GUEST and NETGEAR-GUEST appear in my list of available networks when its on. (neither of which I can connect to - I get "Failed to obtain IP address" then "Couldn't authenticate connection" (its open - no password required).
        The Modem I attempted to connect to - is the standard NBN modem in Australia that I use for my house into my existing network (which works fine).
    • Fademan's avatar
      Fademan
      Tutor
      - I connect a laptop to the router.
      - Disable wifi from the laptop
      - Change the ethernet settings per the guide
      - Connect the laptop to LAN1 , LAN2, LAN3, or LAN4 ports
      - The laptop reports "media disconnected", and none of the port lights up on the router.
      - Connecting the laptop to the WAN port
      - The laptop reports "Unidentified network" and the internet light on the router goes orange.
      - However, attempting to ping 192.168.1.1 reads destination unreachable
      Running the tftp command (using either LAN or WAN ports) gives me "Connect request failed".
      However, if I boot cycle the router, the LAN port/s light up when booting up, then the light turns off once its up and running.
