Jkeyman's avatar
Jkeyman
R7000 router no stable wifi and no upload
Hi,
Since yesterday i have the R7000 router connected to my modem from my ISP provider. I put the modem in DMZ and all looks fine. But i noticed during speed tests at Oklaa that i have nu upload now and then. Also it looks like the internet connectin over the wifi is not constantly there.
Any suggestions?
  • Hi Jkeyman,
    If you connect the device to the modem, will you get a stable connection? Make sure the modem is not a modem/router. If it is a modem/router as one, try to set it to modem only.
    • Jkeyman's avatar
      Jkeyman
      I will try. But I put in DMZ because my ps4 needs a Nat type 2 connection. Before I put the modem in dmz I had Nat type 3.
      • Jkeyman's avatar
        Jkeyman
        I tried turning of the dmz but that did not help.
