HomeITTech
May 15, 2025Follower
r7000 router only shows two lefthand lights
We lost internet this morning. Verizon Fios says that the internet is all good on their end, so it potentially is a problem with our R7000 router. (https://www.netgear.com/support/product/r7000/) ...
May 16, 2025Guru - Experienced User
What color are those 2 led's?
Do you have anything connected to the router wired?
If the wifi led's aren't on, try pushing the wifi on/off button for 2 seconds
