sktn77a's avatar
sktn77a
Virtuoso
Feb 25, 2025
R7000 security settings keep being requested
I have 4 Netgear R7000 routers at different locations.  I just updated one of them to the latest firmware version (1.0.12.216) and am having an issue I don't have with any of the others.  When logging into the router's configuration page, I keep getting the first time setup security page:
Select Password:
Select Password:
Select Question 1:
Select Question 2:
Any idea why it goes strait to this page instead of the main menu (after I enter these values that I've entered several times previously)?
  • FURRYe38's avatar
    Possible something got messed up on the FW update. Best to reset the router and setup from scratch and during the setup wizard, input those security values. Be sure to write down this important information for safe keeping should something happen.
    • sktn77a's avatar
      sktn77a
      Virtuoso
      Thanks.  I've reset the router a couple of times already and gone through the process again but it's still doing the same thing (?)
      • FURRYe38's avatar
        What browser are you using? Happens with a different browser? Try Firefox, MS Edge or Opera?
        Be sure to clear out all browser caches and any saved PW profiles with in the browser as well.
