Pjgadway44
May 05, 2023Aspirant
R7000 setting causes discovery issues
When factory resetting the R7000 router everything works fine where a device gets discovered properly in both the web login and Nighthawk App. As soon as you turn on “Access Control” it messes it up w...
Pjgadway44
V1.0.11.126_10.2.112 is the version. And yes I can repeat the problem every time after doing a factory reset and then turning on “Access Control” only way to fix it is to factory reset again and leave “Access Control” off. It seems to be a bug.
May 05, 2023Guru - Experienced User
Not sure if newer FW would help this or not:
Otherwise, you might contact NG support and let them know about this. This would be beyond forum help here.
Good Luck.
