windsurfer51
Jan 08, 2023Aspirant
R7000 shuts down
For the past few weeks i lose my internet connection at 11 PM I unplug the router, plug it back in and the next night it shuts down at 11 again. In the advanced/security/schedule settings nothing w...
Jan 08, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
You way out of date on FW:
windsurfer51
Fibre modem Gigahub 812-1 No noise on the line and there have been no interruptions to my service from Execulink.
Auto (Channel 4)
Yes but weak
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update? YES
All been done
Yes
Seems rather odd to me that any of these settings would shut the connection down at exactly 11PM every night.
- FURRYe38Jan 09, 2023Guru - Experienced User
And this happens precisely or around at 11pm each night?
Does the Internet or any other LEDs on top show AMBER when this happens?
I would use channel 1, 6 or 11 on 2.4Ghz.
Try newer FW...
- windsurfer51Jan 09, 2023Aspirant
This happens every night at 11 PM on the dot
I am going to reset again and see what happens.
Check the top LEDs for changes from WHITE to AMBER.
There router warm or kind of hot on top?
I keep a laptop fan cooler under any router I have online for 24/7 additional cooling. Helps keep internal electronics cool that can be damaged over time due to hot temps over time.
