RyuMisukiri's avatar
RyuMisukiri
R7000 signal, no internet access
Hello
For the last five years this model has served me well. Recently it has started to give me some grief and I have been unable to find what the issue is. I am not the most educated on routers, modems and internet. Yet I have tried to search for solutions or to find out what is going on. I could use some advice or help if possible.
Info:
AC1900 R7000 Nighthawk
V1.0.11.126_10.2.112
Windows 11
The router is upstairs in the attic with me as our normal ISP router doesn't reach that far. It draws the internet from an outlet forseen by the building. It has worked for five years and I have changed cables, connection points, etc without any luck.
The situation is as following:
Every day once or twice I lose access to the internet. The router remains blue on connectivity while twitch keeps livestreams going, a browser text-based game i play updates in real time until session is closed, acts with internet access (unless i close the browser and restart it than i can't access the sites) the game i play does update in real time without issue until than which puts me off to think something is going on i don't understand. I lose access for about half an hour to an hour sometimes longer. It usually comes back without restarting the router. But until now no dice to fixing it. This is ethernet for the record, my wifi says on my phone no internet access when i look at it when this happens.
The modem from ISP which is  connected downstairs works perfectly, tv signal, internet signal both ethernet and wifi. The router upstairs is the R7000.
What have I done already?
- multiple factory reset
-- They did place a new ISP modem from the company so I resynced it properly multiple times. These issues occured two-three weeks after that placement. Not sure if this matters!
- changed cables, used different outlets
- updated firmware, etc as far it allows me
This piece of equipment was quite expensive for me personally and it would be a shame if something was wrong with it hardware wise. Replacing it would be a problem. So I want to be sure as possible that it is broken/faulty or I am simply aware of a fixable problem. Any help would be highly appreciated.
Thank you in advance!
  • Kitsap's avatar
    Kitsap
    Apr 09, 2024
    Repeat question from previous post:
    What is the temperature environment in the attic where the R7000 is located?
    The image you posted does not provide sufficient detail to determine the brand name and model number of your modem.  Yes, please write it down and type it into your reply.
    The image does show me the device has multiple Ethernet output ports.  This indicates the device is a combination modem and Wi-Fi router.  When you connect your R7000 downstream from your ISP device, the router function in the R7000 is fighting the router in the ISP device for control of your local network.  Your symptoms are a classic indication of a double NAT configuration.  Why is that bad you say?
    See here:  https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
    Based on your original post, I concluded you are trying to connect to Wi-Fi from your ISP modem as well as your R7000.  They are physically located some distance apart.  Please confirm this conclusion.
    If yes, to resolve you double NAT situation, you will need to configure your R7000 as a Wi-Fi access point (WAP).
    Click on the Support section at the top of this page, feed in your model number (R7000), go to the documentation section and download the user manual.
    In the user manual, go to page 83 for detailed instructions on setting your router up as a WAP.
    Some general practices when setting up a WAP, name your Wi-Fi SSID's something different from the Wi-Fi being broadcast by your ISP modem.  Connect a computer to your WAP and determine the IP address of your WAP.  You will use this to log back in to the user interface to make changes.
    Some reference documents to review.
    https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
    https://kb.netgear.com/000064389/How-do-I-find-the-IP-address-of-my-NETGEAR-wireless-access-point
  • It would be helpful to identify the ISP modem by brand name and model number.
    I note the firmware on your R7000 is several versions out of date.  To check, go to the Support section at the top of this page, put in your model number, and look at what firmware is available to download for manual update.
    • RyuMisukiri's avatar
      RyuMisukiri
      ISP is Proximus, Modem is "Internet Box - Sagemcom" This is not mine, but its the same model. The one on the left.
      Thought it may be easier than write it all out. Hope this helps to give more information. The modem in picture is one they used for news article so no wories about exposed information.
      I am going to look into the update of the firmware. I thought it was latest available update but I guess i missed that.
      Thanks! I will keep you posted!
      • Kitsap's avatar
        Kitsap
        Master
