Pisklink
Feb 25, 2016Aspirant
R7000 Slow download speed (wired and wireless)
I have the R7000 for about a year now and originally I had the correct download and upload speeds that corresponds with my ISP rates. At this moment my ISP (cable) delivers 120 Mbps down and 12 Mbps...
- Mar 06, 2016
The RMA indeed resolved the issue.
P.S. I accidently marked the answer of Tarund as the answer to my question.
Can you please remove that?
tarund
Feb 25, 2016Apprentice
Answer to your questions:
The firmware you're on now has been pulled by Netgear because two bugs were identified in the latest firmwares (1.0.5.*** and 1.0.6.***); both were pulled by Netgear. Also, Netgear did not identiy what was wrong with those firmwares. The latest version available, 1.0.4.30, has been known to be the most stable so far. Downgrade process below:
- Factory reset your router first on your current firmware version,1.0.5.48_1.1.79
- After initial setup, downgrade firmware to 1.0.4.30
- Factory reset again
- Setup your router again as if it was a brand new router
If you still have issues, very possible your ISP could be having issues as well in your area. I would recommend calling them to check if any maintenance work or if any performance degradation is being reported in your area.
- PisklinkFeb 26, 2016Aspirant
It would have been nice if Netgear would have notified me in the router web interface that the firmware was pulled, as they do with new firmware notifications.
Nonetheless I tried what you suggested but without any result.
I even tried the following:
- I also tried FW 1.0.4.28 after downgrading to 1.0.4.30
- Factory reset
- Speedtest with wired connection, but no success (exact same results as before)
- Performed a reboot from web interface (192.168.1.1) with FW 1.0.4.28, no success
- Downgraded to FW 1.0.3.56
- Factory reset
- Performed a reboot from web interface (192.168.1.1) with FW 1.0.3.56, no success
- Tried switching LAN port on router, no success / same results
For your information after each factory reset I left the settings at stock settings when performing the speedtest.
That's also the reason I didn't perform a factory reset anymore between each downgrade as described above because before each downgrade it just had a factory reset a few seconds before.
I also connected my desktop directly to the modem and EUREKA, I have immediately 120 Mbps download at my disposal.
Therefore it must be the router!
I'm affraid it's broken because I have no clue anymore.
Any ideas?
- PisklinkFeb 29, 2016Aspirant
Anybody any additional ideas?
- JamesGLMar 01, 2016NETGEAR Employee Retired
Hi Pisklink,
1. You may try changing the mtu size of the router.
2. Try disabling the QoS and see if the same performance.
3. If you have tried all the firmwares available in support site, you may want to try the beta firmware for R7000.
