DESMO1198s
Oct 01, 2017Guide
R7000 SLOWS WAY DOWN with Firmware 1.0.9.10 went back to 1.0.9.6 problem solved. Hold off on update
Just updated the Firmware of my R7000 to the latest 1.0.9.10 from 1.0.9.6 and it cut my download speed from 178MBps on all my devices ( MacBook Pro, iPhone7, iPad Air2) to less than 80MBps. Full pow...
Antonio_Cardile
Oct 12, 2017Guide
Hi,
I have tried a lot of firmwares and also solution that is posted on https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-SLOWS-WAY-DOWN-with-Firmware-1-0-9-10-went-back-to-1-0-9-6/td-p/1383306
1.0.9.12_1.2.23 -> very bad performance I loose more than 150 mbps
1.0.9.10_1.2.21 -> the same problem. Dropping more than 150 mbps
1.0.9.6_1.2.19 -> performance is better but I still loose download speed 20 mbps
1.0.7.12_1.2.5 -> performance is better but I still losse download speed 20 mbps
1.0.7.10_1.2.3 -> performance is good.
I have tested it with Cable and Wifi.
Please check what is going wrong after version 1.0.7.10_1.2.3 ?
Regards
Antonio
