Dustin_V's avatar
Dustin_V
NETGEAR Employee Retired
Feb 25, 2020
R7000 Support, Info & Firmware #EPIC Article
Visit this #Epic article for the latest support, product info and firmware support for the  AC1900 WiFi Router (R7000). R7000 is an 802.11ac (WiFi 5) dual band router, supporting AC1900 (600+1300) Mbps speeds. Built for gaming, streaming, and mobility, the R7000 can handle your high-bandwidth online activities at top speeds while providing exceptional performance and coverage. The R7000’s main features include NETGEAR Armor cyber threat protection, Smart Parental Controls, Dynamic QoS, Beamforming, Smart Connect and more
R7000 Support
For common R7000 Support topics, such as Password resetting, R7000 Login, R7000 Firmware, visit our R7000 Support page.
How Can I Buy the R7000?
The Nighthawk R7000 is available directly through the NETGEAR online store, which offers Free 2-Day Shipping, 100% Satisfaction Guarantee, and Simple, Secure Checkout.
Buy the R7000 Router
Join the Discussion on R7000
To start a discussion or to view popular discussions on the R7000, you can visit the Nighthawk WiFi Routers board on the NETGEAR Community Forums.
Alternative to the R7000
The Nighthawk AX4 WiFi 6 router is a great upgrade from the R7000. The AX4 uses the latest and greatest WiFi standard, WiFi 6, giving you optimal WiFi performance, more connected capacity, and faster speeds.
Learn more about the Nighthawk AX4 WiFi 6 Router
See more AC1900 WiFi Router (R7000) discussion or tag your posts with #R7000
  • I purchased Netgear's Nighthawl R7000 just in May 2020. This device started dropping internet few Months after purchase, right after the 90 days support is over. The phone app is telling me the firmware is up to date but online their website is showing a different firmware. I called the tech support who is asking me to buy technical support without telling me what’s wrong with the devise. This is fairly new device. Not 5 years old or no longer supported. In fact, they are still selling the same device people and others are having the same issue after their 90 days. If it was a defect on this particular device then why others are having the same issue? And, why one have to pay to fix it if it’s a defect? It’s obvious it was set up this way.
    Other customers said ‘’the technical support from Netgear is pathetic, unprofessional and fraud. Their team has only one motive: to sell extended warranty (beyond 90 days) and dupe customers. They purposefully create issues and when customers call for help, they force them to buy 3m/6m/1year support at extra cost and fix the issue. This is their game plan and any amount of escalations makes no difference. Sincere advice: avoid buying their products and tech support.’’ This is true and honest statement. I myself regret buying from Netgear and would not recommend anyone falling in the same trap. Call them and check reviews to confirm it yourself.
  • Hello,
    I purchased R7000 AC1900 in April 2021. It recently started disconnecting internet access all connected (wireless and wired) devices at seemingly random intervals. This occurs maybe 3 or 4x per day. This started happening approx a week and a half ago. If I power cycle the router, the connection is restored. But the disconnection will still eventually occur. Status lights do not appear to change at all after devices are disconnected. Yes, I did attempt factory reset.
    After the crashing I manually updated the firmware to Firmware Version
    V1.0.11.128_10.2.112 provided in this article... it looks like it was the latest so far as this week https://kb.netgear.com/000064024/R7000-Firmware-Version-1-0-11-128. Unfortunately, I still observe the same disconnection issues with the new firmware. I repositioned the router as well in the interest of any potential physical problem. There is no change.
    Is there another firmware fix to come? I really need a consistent router connection.
    -MichaelC
    • davemays's avatar
      davemays
      Guide
      It's time to abandon these devices.
      I had to put mine on a mechanical timer that powers it off and back on every night to keep it from crashing/disconnecting periodically.
    • CatintheHat's avatar
      CatintheHat
      Tutor
      Your best bet is to throw this thing in the trash and get an eero. After dealing with the same thing you did, its what I ended up doing.
