Miles49's avatar
Miles49
R7000_UM.pdf
I have tried to download the router's newest user manual several times over several days and each time Adobe reports that the file is corrupted.  I want the new user manual because my manual tells me to use the router's built-in update function,  but I tried that on an earlier R7000 and the router was distroyed by the update. This resulted in my having to buy a new one since that router was out of warranty. I called customer service and they informed me that I should never use that function.  I should update the firmware manually.  My manual does not tell me how to do that.
I want that new manulal!
Can someone tell me how to download the newest user manual for the R7000 router?
  • Miles49, I am able to successfully download the User Manual for the Nighthawk AC1900 Smart WiFi Router (Model R7000) from here. The document is dated January, 2019 (186 pages). Perhaps you can try the download using a different PC?
    P.S.:  It is unclear how the router's built-in firmware update process would destroy the device.
    • Miles49's avatar
      Miles49
      I was able to down load the user manual on another computer, actually a tablet.
      I don't know definitively how the update function destroyed of the older R7000 router either.  All I know is that after updating the router firmware it would not longer function.  I couldn't even log into it.  I contacted NetGear customer service and spent aboout four hours with them trying to recover the router to no avail.  The IT person told me it was dead, not recoverable and, since it was out of warranty, I would have to buy a new one.  He said that most likely the update was corrupted during download and a non-functioning router was the result.  I did buy a new one and have been very reluctant to update the firmware.
      • michaelkenward's avatar
        michaelkenward
        What did the LEDs on the thing look like?
        If the power LED was not as expected, flashing or amber, then there may still be ways to bring it back to life. Many many people have done so.
        How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
        I hope you didn't not phone someone on the basis of a web search.
        If you called a number that you found with a web search, that almost certainly had nothing to do with Netgear.
        Netgear handles paid for support through GearHead Technical Support.
        GearHead Support
        Web searches can deliver results that scream "Netgear support" at the top but that turn out to be anything but. Using them can be dangerous, for your network and your bank balance.
        Sounds like someone who didn't know what they were talking about.
        The most reliable way to update the firmware is to follow the manual approach with a wired connection to the router. The manual explains how to go about that.
        How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
