michintexas
Jan 02, 2017Aspirant
R7000 upgrade to V1.0.7.6 breaks smart devices
I upgraded my firmware to V1.0.7.6 on my R7000 and connections to all my smart devices were broken and I cannot re-set them. I have tried rebooting the router and that didn't work. I then re-set my devices to factory settings but I cannot connect to the network. Did something change in the firmware that affects smart devices? I have multiple devices with issues but we can use Wemo light switch for this discussion.
I did not take note of the previous firmware version so have not downgraded yet.
Thanks in advance.
Did you reset the router to factory default also?
- netwrksMaster
- michintexasAspirant
No, I didn't. That'll wipe my SSID and network keys, right? I'll give that a shot now...
- netwrksMaster
Yup, resets everything to factory default. You will ned to reconfig the roter from scratch..
