shayaant
Jun 03, 2017Aspirant
R7000 usb 3.0 doesn't work
Hello, My nighthawk usb 2.0 port works fine with both my "My book external hdds", but fails for both with the usb 3.0 port. I'm on firmware version, V1.0.5.48_1.1.79. Both external drive...
- Jun 22, 2017
It's the latest firmware. I just ran a factory reset and then formatted the drive in NTFS. Seems to work now. Thank you.
JamesGL
Jun 04, 2017NETGEAR Employee Retired
Hi shayaant,
You can download the firmware on the link below.
IrvSp
Jun 05, 2017Master
JamesGL wrote:Hi shayaant,
https://www.netgear.com/support/product/R7000#download
Isn't it about time to change the STICKY for the old R7000 flash to this new one?
