shayaant
Jun 03, 2017Aspirant
R7000 usb 3.0 doesn't work
Hello, My nighthawk usb 2.0 port works fine with both my "My book external hdds", but fails for both with the usb 3.0 port. I'm on firmware version, V1.0.5.48_1.1.79. Both external drive...
- Jun 22, 2017
It's the latest firmware. I just ran a factory reset and then formatted the drive in NTFS. Seems to work now. Thank you.
shayaant
Jun 13, 2017Aspirant
exFat, I tried V1.0.8.34_1.2.15, still doesn't work for either usb port.
JamesGL
Jun 14, 2017NETGEAR Employee Retired
Hi shayaant,
As what IrvSp suggested, try to use the NTFS file format.
- JamesGLJun 18, 2017NETGEAR Employee Retired
Hi shayaant,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- shayaantJun 18, 2017Aspirant
You guys have been great, all the responses were prompt and reasonable. I don't have any options to reformat/backup my current ex-fat system, but I'll get another hdd soon and try this out.
I do wish ex-fat was more easily supported :/
My only problem now is I've noticed streaming/network latency issues with the latest firmware.Where can i get V1.0.5.48_1.1.79 to confirm this?
