cplex
Jul 01, 2018Aspirant
R7000 V1.0.9.32_10.2.34 cannot find Chromecast devices after upgrade
Hi everyone, I updated my R7000 to the latest firmware today: V1.0.9.32_10.2.34 and now I can't seem to find my Chromecast devices on the connected devices list. I've searched around the internet an...
- Jul 02, 2018
Same here had roll back, working now even my ring doorbell had stopped due to poor 2.4 wifi stop
cplex
bump
michaelkenward
Jul 02, 2018Guru - Experienced User
cplex wrote:
bump
At the weekend? Don't be impatient.The Netgear team probably isn't around then.
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
This is a nuisance because you then have to reconfigure the device all over again.
You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.
