Hoyty
Aug 26, 2015Apprentice
R7000 WAN connectivity issues
In the last week or two I have suddenly had WAN connectivity issues. The LAN / Wi-Fi works fine and I can connect to router but not past it. I usually reboot both cable modem (Comcast Ubee 3.0) and t...
- Aug 26, 2015
I’m not sure if the R7000 WAN / Internet status shown in the web interface shows the WAN side DHCP lease time, but if it does that might give some clues as to what is happening. I suspect that maybe DHCP renewal could be failing.
You could try accessing the modem’s web interface but I’m not entirely sure if the R7000 and/or your PC will be able to do this with the R7000 in place;
http://www.ubeeinteractive.com/support/consumers/faq/how-do-i-log-modem%E2%80%99s-web-user-interface
Otherwise connect a PC to the modem, and power cycle the modem. At a Command Prompt type ipconfig /all and look at the DHCP lease time.
Babylon5
Aug 26, 2015NETGEAR Employee Retired
Hoyty
Sep 02, 2015Apprentice
Well just as suddenly as it started it stopped? My guess is flakiness on Comcast end. Thanks.
- seanvreeSep 03, 2015Tutor
I've actually been having the same issue with my R7000. It drops the internet connection about once every other day. If I reboot the router, it will not pick up the internet connection....I have to power cycle the modem (Motorola Surfboard), and only then reboot the router will it start working.
I also thought it was a lease issue, but it's not. After I reboot the cable modem...I still have the same external IP.
It's very random and intermitten, so it's difficult to troubleshoot.
Very frustrating.
