Hoyty
Aug 26, 2015Apprentice
R7000 WAN connectivity issues
In the last week or two I have suddenly had WAN connectivity issues. The LAN / Wi-Fi works fine and I can connect to router but not past it. I usually reboot both cable modem (Comcast Ubee 3.0) and t...
- Aug 26, 2015
I’m not sure if the R7000 WAN / Internet status shown in the web interface shows the WAN side DHCP lease time, but if it does that might give some clues as to what is happening. I suspect that maybe DHCP renewal could be failing.
You could try accessing the modem’s web interface but I’m not entirely sure if the R7000 and/or your PC will be able to do this with the R7000 in place;
http://www.ubeeinteractive.com/support/consumers/faq/how-do-i-log-modem%E2%80%99s-web-user-interface
Otherwise connect a PC to the modem, and power cycle the modem. At a Command Prompt type ipconfig /all and look at the DHCP lease time.
Hoyty
Sep 02, 2015Apprentice
Well just as suddenly as it started it stopped? My guess is flakiness on Comcast end. Thanks.
seanvree
Sep 03, 2015Tutor
I've actually been having the same issue with my R7000. It drops the internet connection about once every other day. If I reboot the router, it will not pick up the internet connection....I have to power cycle the modem (Motorola Surfboard), and only then reboot the router will it start working.
I also thought it was a lease issue, but it's not. After I reboot the cable modem...I still have the same external IP.
It's very random and intermitten, so it's difficult to troubleshoot.
Very frustrating.
- Babylon5Sep 03, 2015NETGEAR Employee Retired
DHCP leasing does not necessarily result in a different IP address, you can have the same IP renewed.
- seanvreeSep 03, 2015Tutor
So what's the process for testing if this is the issue?
I’m not sure if the R7000 displays the WAN IP lease time anywhere, but if you connect a computer directly to the modem, check you have internet access, then go to a Command Prompt and type ipconfig /all you will see the lease time that the modem set for the connected device. If you then reconnect the router it’s fair to assume that it will be allocated an IP with the same lease time. DHCP renewal normally occurs at the half-time point, so for example the router would attempt to renew a lease at 12 hours if the lease time is 24 hours.
