Hoyty
Aug 26, 2015Apprentice
R7000 WAN connectivity issues
In the last week or two I have suddenly had WAN connectivity issues. The LAN / Wi-Fi works fine and I can connect to router but not past it. I usually reboot both cable modem (Comcast Ubee 3.0) and t...
- Aug 26, 2015
I’m not sure if the R7000 WAN / Internet status shown in the web interface shows the WAN side DHCP lease time, but if it does that might give some clues as to what is happening. I suspect that maybe DHCP renewal could be failing.
You could try accessing the modem’s web interface but I’m not entirely sure if the R7000 and/or your PC will be able to do this with the R7000 in place;
http://www.ubeeinteractive.com/support/consumers/faq/how-do-i-log-modem%E2%80%99s-web-user-interface
Otherwise connect a PC to the modem, and power cycle the modem. At a Command Prompt type ipconfig /all and look at the DHCP lease time.
Greeneyej
Oct 18, 2015Aspirant
I had the same problem, on the 5GHz wireless, with the .30 FW, "incorrect password "
Just rolled back to .28 and all is fine again.
- coldairOct 21, 2015Aspirant
Check your router logs, i have been experecing DoS attacks on my comcast netgear business class modem which cause the sympthoms you are describing
