hbk_seanmichael
May 07, 2017Aspirant
R7000 What firmware? Stock? DD-WRT? Tomato?
Is stock fine for me? Or shoud I use a different firmware? My internet plan is 125mbps download 20mbps upload I do a lot of streaming at home on my home networking. Wife streams netflix while ...
- May 07, 2017
Stock should give you the best performance. Go to third party firmware for features. These days, DD-WRT would be my last choice. Go with Tomato or Asuswrt-Merlin. Both support hardware acceleration.
May 07, 2017Guru - Experienced User
Theres OpenRouter FW as well. All tailored or NetGear routers and mostly based on NG FW and UI.
AhnFire
May 10, 2017Guide
Don't fix what ain't broke! But if it's broke (like mine), I went with Tomato 138 AIO from openrouter. Works better for me, not perfect, but I think I have something else going on in my setup. Just make sure you follow the directions and after each flash, do a factory reset. Good luck!
