raddoc54
Feb 25, 2019Aspirant
R7000. What WiFi adaptor do I need to go into the back of a DISH receiver (VIP211K) to get internet?
Need Netgear WiFi adaptor to plug into the back of a DISH Satellite Receiver (VIP 211K) so TV can get internet connectivity. DISH said Model no. WNDA3100V2 would work, but can only find WNDA3100V3 on...
- Feb 26, 2019
When I had Dish you could order the adapter from Dish and it was so much cheaper then anyplace else that I bought 2.
If Dish still offers the adaper and good price go there.
They have 2 different chipset from different manufacturers so they are not the same. Would use different drivers which would mean your Dish box OS supports it. Only folks that can answer your question for sure is Dish and someone who has done it.
michaelkenward
Feb 26, 2019Guru - Experienced User
I do not understand the question.
A satellite receiver should just provide an Ethernet outlet that you connect to the WAN input in the router.
The TV then connects to the router either with wifi or with an Ethernet cable connected into the back of the router.
The WNDA3100V2 is a USB wifi adapter that works on a Windows PC. It will not work if you plug it into a TV or anything else for that matter.
Is there any reason why you have R7000 in your message footer? Do you own one of those?
- myerswFeb 26, 2019Master
- raddoc54Feb 26, 2019Aspirant
Thanks for your reply.
- michaelkenwardFeb 26, 2019Guru - Experienced User
Be careful about what DISH tells you. They have altready proved that they do not know what they are talking about.
This suggestion, for example, is complete tosh:
DISH said Model no. WNDA3100V2 would work...It proves that they do not understand how Netgear's USB adapters work.
Yes, that is the exact adaptor model they told me to purchase and then simply plug it into my DISH satellite receiver USB port. Are you sure it will not work? My wireless WiFi router is Netgear R7000.
