r4v3n6
Jul 02, 2016Aspirant
R7000 WiFi password change not possible?
When I get to Basic - Wireless setting where I can change SSID name, WEP, WPA, WPA2 etc, there is no place for changing the password. I have R7000 with latest firmware V1.0.5.70_1.1.91. Is this a kno...
- Jul 12, 2016
Our engineers have taken note of this and will be fixed in the next official firmware release.
Thank you!
netwrks
Jul 02, 2016Master
It's supposed to be under Basic>Wireless>Security Settings
- Retired_MemberJul 04, 2016
you have to select a security BEFORE the option to change password is available If "none" is selected then no password option is available.
If this is not the case then reset to factory defaults
- r4v3nJul 06, 2016Tutor
I did choose both WPA and WPA2, but there is nothing appearing to be able to input a password. :(
Having to reset all my configuration just to change the password seems very odd. :( This is one of the most basic settings of a router.
- Retired_MemberJul 06, 2016
I've tried every setting I can think of and cannot recreate your problem. I'm guessing your router FW and or config is corrupt and would suggest a reset to factory defaults, do not use a saved config file. I would also reset the Browsers to default and clear their cache.
If same after....reload FW and use different PC to setup. If using using Genie APP Don't!
