Gil80's avatar
Gil80
Apprentice
Aug 13, 2017
R7000 WiFi schedule issues
Hi all.
The WiFi schedule is buggy and I wanted to know if someone has an idea to make it work correctly.
1. The router time zone is not correct - this is just an observation. I do not know where there router obtains it's time zone since it's never switching on or off at the desired time setting.
2. The GUI Start and End time is not clear nor user friendly. Does it refer to start of the 'switch off' schedule? Or does it refer to 'start the wifi antenna'?
It would be much clearer if it was written as WiFi On and WiFi Off.
Hope someone can help. This is relatively an easy feature to implement. I have no idea why such a simple thing won't work as expected
  • Hi Gil80,
    You can change the Timezone under security>schedule.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Gil80,
    • JamesGL's avatar
      JamesGL
      Hi Gil80,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
      • JamesGL's avatar
        JamesGL
        Hi Gil80,
        If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
