Scast
Jan 14, 2017Tutor
R7000 WIFI stopped working
The WIFI on my Nighthawk R7000 stopped working after owning the device for 20 months. When it worked, it worked great, however spending close to $200 for 20 months of WIFI functionality is hardly a ...
- Jan 14, 2017
Michael,
The switch is the problem. It is not turning on the WIFI. I just purchased an AC1750 which is a step down but wirecutter is high on it which is good enough for me. I am hoping the marginal difference is undetectable for my needs.
Scast
Jan 14, 2017Tutor
Michael,
Thank you for your reply. Yes I failed to mention I also did a factory reset. The Wireless Settings screen in Advanced Setup tells me the Wireless ON/OFF is set to OFF as indicated in the Wireless enable box for both 2.4 & 5 - (This action is currently disabled until the wireless On/Off button is pressed)
I saw nothing in the support community indicating a solution. I may end up opening the unit since I have nothing to lose at this point. It is a shame because the unit provided sufficient bandwidth over the 5G to stream HD video to a crappy wireless on my Samsung TV and also stream music to my streamer with virually no drop outs. Both these units are located on the 1st floor and are approx sixty feet from the Router on the second floor.
michaelkenward
Jan 14, 2017Guru - Experienced User
Scast wrote:The Wireless Settings screen in Advanced Setup tells me the Wireless ON/OFF is set to OFF as indicated in the Wireless enable box for both 2.4 & 5 - (This action is currently disabled until the wireless On/Off button is pressed)
Remember, on some Netgear devices the physical switch and the "software" switch are independent. You may think you have set the wifi on in the browser interface, but nothing happens until you turn on the physical switch.
I mention this because someone turned up here recently complaining about that.
By the way, I find it easier to feed a smart TV with a hard-wired powerline plug. More reliable than wifi.
- ScastJan 14, 2017Tutor
Michael,
