Austen
Jan 25, 2017Aspirant
R7000 wired device no internet
Hi, I have an R7000 which has been working perfectly for some time. Yesterday, my playstation 4 had no internet (wired). Everything that is connected wirelessly has internet and the playstation ...
- Jan 31, 2017
Thanks for the replies,
It seems that suddenly my internet settings on the ps4 just stopped working.
I have it manually setup for a static ip address so i can open ports to the ps4.
I just changed the settings to automatic and it worked fine.
I fixed the static ip by setting the router to give a specific ip address to the mac address on the ps4.
Strange that it worked for years and now suddenly stopped.
I think it was to do with the subnet mask i had set to 255,255,255,0.
On the router it was 255,255,255,128. I tried that on the ps4 and all that happened was it had to think a bit longer before coming up with "internet failed".
Anyway, all is working fine now, thanks!
Austen
Jan 31, 2017Aspirant
ElaineM
Feb 01, 2017NETGEAR Employee Retired
Thank you too for the update!
