Belloh01
Jun 28, 2018Aspirant
R7000 with DGND 4000 as modem
I am considering to buy the R7000 AC 1900 Dual Band WiFi and to download the ExpressVPN App. Currently I have my ADSL line linked to the DGND 4000 modem router. Will it be ok, when I link the the DGN...
- Jun 28, 2018
Thank you for your reply. My ISP is MWEB in South Africa. The connection is via PPPoE.
Before, I tried the Asus R AC68U. It did not connect to the internet. According to the Asus technical support the router does not link to ADSL, only to VDSL
Nevertheless i am going to buy the R7000 and give it a try.
Belloh01
antinode
Jun 28, 2018Guru
> ADSL, only to VDSL
I looked quickly at the "ASUS RT-AC68U user's manual in English", and
the only reference to "DSL" I found was:
Check the status indicators on the ADSL modem and the wireless
router. If the WAN LED on the wireless router is not ON, check if
all cables are plugged properly.
http://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC68U/E14013_RT-AC68U_manual_v2.pdf
> Generally, I don't think that it cares about the DSL details.
Still true.
- Belloh01Jun 29, 2018Aspirant
Thanks antinode, the WLAN LED was on. I followed already the advice of the Asus specialist to return the router and I will now buy the R7000.
