djchap's avatar
djchap
R7000 with Raspberry Pi zero-w Pi-hole
I intend to setup a Raspberry pi zero -w with pi-hole for DNS serving on my r7000 network.
Pi is powered via mini USB. Do either of the Router USB ports provide power?
save to use this port to power only the PI/
Thank you
  • > [...] Do either of the Router USB ports provide power? [...]
       All USB ports provide power; it's part of the spec.  The question is
    whether it's enough, but it should be safe to run the experiment.
    • djchap's avatar
      djchap
      thank you. exactly the info i was looking for
