mzoomers's avatar
mzoomers
Follower
Dec 14, 2018
R7000P - 5Ghz channel broken - support not answering
Unfortunately, the 5Ghz channel of my R7000P is not working. I've tried everything to get it to work, from changing WiFi configuration to installing different firmware versions, but without luck.
Reading some of the other threads seem to suggest it to be a common hardware issue that affects this model.
Would be great if support could finally look into the case that I opened nearly a month ago - case #40714445.
  • Hello mzoomers
    I have escalated your case for someone to contact you about the issue.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello mzoomers
    DarrenM
    • mexscrabbler's avatar
      mexscrabbler
      Initiate
      Please let me know if/when this is answered. I'm having the same problem and all old posts on this subject are inconclusive.
  • Was this ever solved?  I have the R7000P and lost 5Ghz after installing the latest firmware (v1.3.1.44_10.1.23). I was able to get 5ghz back after reinstalling the previous firmware version. I'd be interested if yours was a firmware or hardware issue.
      mexscrabbler
      Initiate
      Not in my case. I reinstalled the previous version and it didn't solve the problem. In the end I decided to revert to the latest version and live with only having the 2.4 Ghz setting.
      However, I would really like to hear from Netgear about this!
      • DarrenM's avatar
        DarrenM
        anyone having this issue can you Pm me your serial number of the router so we can look deeper into this issue.
        Thanks
        DarrenM
