chris_st's avatar
chris_st
R7000P + VPN: accessing router config page
Finally managed to get the VPN with a windows client working, however, when the client is connect and I am trying to access 192.168.1.1 I get the REMOTE (Client) router, NOT my local router.
Is this to be expected or is there something wrong with my setup? Best solution is to change the remote routers IP? how do I ensure that the remote router does not have an IP that already has been assigned by my local router to another machine?
thanks vm
  • Hi chris_st,
    It is normal that when the client is connected to the VPN, you can access the Remote router. This is because you are connected to the network of the remote router. If you want to access the local router, disconnect from the VPN.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi chris_st,
    • JamesGL's avatar
      JamesGL
      Hi chris_st,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
