CaliforniaQuick's avatar
Jan 02, 2020
R7000P and Frontier FIOS 500/500 slowness
`So I've had the R7000P (AC2300) for a while now with Frontier FIOS 150/150 here in Southern California, and recently upgraded to 500/500. I'm running straight ethernet directly from the ONT to the WAN port of the router. Nothing inbetween. I'm currently on Firmware Version V1.3.1.64_10.1.36
When I run a speedtest directly from the router itself, I never achieve more than 250/300. I have dynamic QOS turned off, and IPv6 turned on.
When I connect a Windows laptop directly to the ONT I get 504/501 at speedtest.net.
Suggestions?
  • Version 1.3.1.44 was the version that supported netgear armor rollout.
    I'd actually try the version prior to this as many device had issues with the initial rollout of armor.
  • plemans's avatar
    Try factory resetting and manually re-installing the router.
    I've found that sometimes the qos settings can be retained even when you shut it off.
    Give this a shot first and let me know how it goes .
    • CaliforniaQuick's avatar
      CaliforniaQuick
      So I performed the factory reset of the router, and re-setup the router. No such luck. When running speedtest on the router I get 249 DL / 205 UL, when I run speedtest.net using Chrome from a MacBook connected to the router and no A/V, I get 157 DL / 300 UL.
      So...I'm still stuck same place. Obviously, my firmware did not roll back with the factory reset.
      • plemans's avatar
        Factory resetting only removes the settings. You can try downgrading the firmware
