stubbyjames's avatar
stubbyjames
R7000P Guest Network and Printer with Allow guests to see each other and access my local network off
A couple of question about the guest network on R7000P.
One. if I set advanced options for the router, i.e., turning off UPnP. Will this also be turned off for the guest networks?
Two. If I turn off/deselect Allow guests to see each other and access my local network, is there any way I can have a PC on the guest network configure/use/communicate with a printer?
  • > One. if I set advanced options for the router, i.e., turning off UPnP.
       UPnP is a global feature, unrelated to the firewall-like rules used
    to implement a guest network.
       "a printer" on your LAN?  I'd say that "[not] allow guests to [...]
    access my local network" pretty explicitly answers that one.
       What, exactly, are you trying to achieve?
    • stubbyjames's avatar
      stubbyjames
      I have a lot of iot devices, some which require ethernet, and just a couple of pc's and a printer. I was thinking it would be nice if I could put my pcs and printer on the guest network and everything else on the primary network. However, if I do this, it seems that I could not print from my pcs with the isolation option selected. I was looking for some way to set this up.
      • antinode's avatar
        antinode
        Guru
        > [...] I was thinking it would be nice [...]
           Not an actual goal.  _Why_ would that "be nice"?
        > [...] guest network [...] primary network. [...]
           It's really one network, with some optional firewall-like rules to
        restrict communication involving "guest" clients.  If you want
        unrestricted communication with some device, then you don't want it to
        be a "guest", and you don't want the device with which it communicates
        to be a guest.  Or you _do_ want that "Allow guests" option.
        > [...] I was looking for some way to set this up.
           Exactly what "this" is remains a mystery.  "I want these devices
        separate, but I want them to be able to communicate"?  At least one of
        us is confused.
