cmccaghren's avatar
cmccaghren
r7000p power blinking orange after failed update
I have read through some posts on this problem, is it just dead? it is just over a year old .
  • > I have read through some posts on this problem, [...]
       Think for a moment about how little useful unformation that
    non-description conveys to the non-psychics in your audience.
    > [...] is it just dead?
       Have you tried the TFTP recovery procedure?
          https://community.netgear.com/t5/x/x/m-p/1622096
    • cmccaghren's avatar
      cmccaghren
      I have attempted it a couple of times, the links in the procedure do not work
      • antinode's avatar
        antinode
        Guru
        > not work
           The TFTP recovery procedure is a multi-step procedure with many
        variables, and many opportunities for user error.
           "attempted it" or "do not work" is not a useful problem description.
        It does not say what you did.  It does not say what happened when you
        did it.  As usual, showing actual actions with their actual results
        (error messages, LED indicators, ...) can be more helpful than vague
        descriptions or interpretations.
