jackcheung0's avatar
jackcheung0
R7000P slow upload speed
Netgear R7000P
Firmware V1.3.3.154_10.1.86
QoS - Disabled
Access control - Turned off
Speedtest on R7000P
50mbps Download
2.8mbps Upload
Speedtest on Nest Modem
52mbps Download
20mbps Upload
Both tested over ethernet and wifi, same results
Factory reset and manually configured, no change
NBN box > Google Nest > R7000P Router mode
  • michaelkenward's avatar
    michaelkenward
    If you are using the Google Nest modem and the R7000P in router mode, you can expect problems.
    Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
    This explains some of the other drawbacks.
    What is Double NAT? | Answer | NETGEAR Support
    Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point.
    It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
    A lot of people use an Orbi system in AP mode, especially if they have a decent router in front of it. Only you know which of your two routers provides the best features for your needs.
    • jackcheung0's avatar
      jackcheung0
      R7000P was here before the Google Nest as it was provided by the ISP
      Didn't have a problem with the R7000P in router mode until a week ago
      Do you advise to set the R7000P into bridge mode?
      I use the R7000P because it provides better WIFI coverage and 4LAN ports
      which the Google Nest lacks
