MSDMgoo
Sep 03, 2018Aspirant
R7000P to Frontier Arris NVG443b - can it be done?
I've been unsuccessful hooking up my R7000 AC2300 to Frontier. The existing is Arris NVG443B. Have I chosen the wrong unit? Tried going from Arris LAN to R7000 internet and lost internet all around...
- Sep 03, 2018
> [...] this will get me started down the right path with the wi-fi only
> option. [...]
I don't know what that means. A wireless access point is called that
because it provides wireless access, but when a router is configured as
a WAP, its LAN Ethernet ports should still work, so it would not be
"wi-fi only".
> [...] The Netgear unit locked up the Arris unit's internet (blue to
red) security? [...]
I don't know what that means. As I said, properly connected, even in
full-function router mode, an R7000P should not greatly disturb the main
router to which it's connected.
> [...] I'm afraid I'm clueless as to what eq I need, [...]
As I said, adding a WAP (such as an R7000P configured as a WAP)
should be a reasonable way to go for improved wireless coverage.
> [...] Frontier could only offer advice to buy their Netgear extender
> that they admitted was sub-optimal. [...]
I don't know what that is, either.
MSDMgoo
Thank you, this will get me started down the right path with the wi-fi only option.
Regarding devices, with the Arris surfboard there;'s no range for laptop, AC and n receivers in a PC, the i-phone won't connect to 5g unless there are no walls between me and the Arris unit. The nighthawk looked like a good way to go and I undoubtly bought more or something different than I should have. The Netgear unit locked up the Arris unit's internet (blue to red) security? - and Frontier helped me reset the unit to get the internet flowing through the unit again.
I'm afraid I'm clueless as to what eq I need, Frontier could only offer advice to buy their Netgear extender that they admitted was sub-optimal. My service is fiber to analog - Vantage.
antinode
Sep 03, 2018Guru
> option. [...]
"wi-fi only".
- MSDMgooSep 04, 2018Aspirant
It all started working as intended yesterday afternoon and life is good again. Thanks for the help! The Nighthawk puts out a strong signal and is easy to connect to the WiFi which maintains a strong signal throughout our house and walls!
