craftynetworker's avatar
Apr 13, 2018
R7000v2 VLAN Not Working
Hi All,   Just spoken to Netgear support (the free one) not a huge help so hoping that I can get some more assistance on here before I make the annoying decision to send this device back.   I hav...
  • schumaku's avatar
    Apr 13, 2018
    Hello Charles,
    craftynetworker wrote:
    Problem I have is with VLAN's they seem to be quite poor on these devices. The limited setup options leads me to assume that you cannot have a different IP range for your VLAN's?
    There is just very limited support for some tagging on the WAN side of the Netgear consumer routers (Nightawk, Orbi, Orbi Pro) - mainly to allow the configuration of an Internet access which is operated in tagged mode. Beyond, there is no support for VLAN tagging - so no multiple VLANs on the LAN side of the router, no dedicated VLAN for the guest network (Netgear seems to be proud of their limited wireless-only guest isolation link layer technology for this purpose). Amazing that their customer service was not able to answer this.
